To process data from large array in steps & display the results
I am facing problem in processing the elemnets of large array 2MB points, i.e i want to process first 250000 points & display & again process points from 250001 to 500000 & display continue till 2MB or store the result in array & finally display all points at a time. Plz suggest me a solution.
sayaf
(2,461 Views)
Hi Sayaf
It sounds like you need to use "Array Subset.vi" to split the 2000000 into 250000 element blocks.
Set the index on Array Subset to 0 and then increment by 250000 after processing and displaying each block.
Good luck
Neil
(2,455 Views)
