To open an exe in labview which required to be opened as an administrator
I want to open an exe file in labview. I want it to be opened in cmd which is used as an administrator. I have a program which can open a normal exe files with default cmd prompt but I want to open an exe as an administrator.
(2,604 Views)
In Windows 10, when I right click on Labview 2016 and select run as administrator, and then I do a System Exec with ipconfig /registerdns which requires elevation, it works (if I don't run as admin, it asks for elevation). Is that what you are trying to do?
(2,553 Views)
