To log and export data to excel file with column headers
Hi...
I need to log sample number, date and time, voltage, current and power to a excel file and need to export that data to a specified location on the system. Can anyone help me with this?
Thankyou.
(2,282 Views)
Hi stark,
Sure we can help…
  • What exactly is an "excel file"? Is a simple CSV text file sufficient (as its much easier to create)?
  • What is a "location in the system"? Do you mean specific folder and filename? You can define this easily using a filepath constant…
(2,266 Views)
Excel file means .xlsx file and save location would be the current VI folder.
(2,242 Views)
Accepted by topic author stark8
Hi stark,
Use the ReportGeneration functions to create/handle XLSX files.
There are example VIs in the example finder…
Which is a bad decision, you better use "public" folders like Desktop or UserAppData…
There is a File constants palette with lots of predefined path constants (including CurrentVIPath), including a function to select several pre-defined folders in typical Windows environments!
(2,221 Views)
Hi....
Can you send me an example program for this. I can't find examples for the above.
Thankyou
(2,061 Views)
Hi stark,
What is "this" and what is "the above"?
Please ask specific questions. It also helps to quote other messages (like I do) to provide context for your questions!
Maybe you are talking about the Report Generation functions:
(2,049 Views)
