Timing the dataacquisition
I need to measure data in a while loop every second. How can I in LV 7.1 make sure that my vi acquires the data exactly every second? As an idea I thought it may be useful to use a queue, due to further processing, but I'm not sure. I'm curious to see your suggestions.
Thank for help.
Mara
Message 1 of 15
(4,293 Views)
Hi Mara
If you want to measure data every second EXACTLY, you need to use a trigger.
It can be generated by your card.
If you don't need the exact timing, you can use a timed while loop in parallel to your other processings.
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
Message 2 of 15
(4,293 Views)
Hi Doc-Doc
It has to be exactly every second. I never used a trigger before. How do I generate a trigger and how have I to handle it?
Mara
Message 3 of 15
(4,293 Views)
Hi Mara
Sorry, you don't need to generate a pulse.
You can use :"C:\Program Files\National Instruments\LabVIEW 6.1\examples\daq\anlogin\analogin.llb\Cont Acq&Chart (what you want of difficulty)".
There you will find that you can set your timing very acurately and read the data from time to time (or whenever you want).
Cheers.
Doc-Doc
Doc-Doc
Message 4 of 15
(4,293 Views)
If it really needs to be exactly every second you should probably consider using LabVIEW RT. Even with the trigger method Doc-Doc mentions there could be significan latencies if you are using Windows.
Stuart G
Message 5 of 15
(4,293 Views)
Hi Doc-Doc
Unfortunately I haven't a DAQ. I should trigger a oscilloscope. Since I use a TCP/IP connection it would be preferable if the trigger supports this.
Mara
Message 6 of 15
(4,293 Views)
Hi Stuart
There is no need to use LabVIEW RT to take a measurement every second. A continuous bufferd acquisition has no latency (at least not more than 1 clock cycle on the card).
Doc-Doc
Doc-Doc
Message 7 of 15
(4,293 Views)
Then I don't understand exactly your process. Do you want to trigger a scope every second EXACTLY, and want to get this data on your PC ?
I am correct ?
In this case, you should plug a function generator set to 1 Hz to your Scope trigger input.
And check by TCP/IP whenever data is ready for transfer.
Do not try to use soft trigger to trigger your scope by TCPIP : it will never be acurate since you don't know how much time it takes to send your order to your system. Even with a RT system
Doc-Doc
Message 8 of 15
(4,293 Views)
Correct...I didn't see where she was doing a buffered acquisition.
Message 9 of 15
(4,293 Views)
Well I'm not a LabView master (not yet). So how do I realise a continous buffered acquisition?
Mara
Message 10 of 15
(4,293 Views)
