Timing of RT-application on cRIO
Hello
I am starting a project on cRIO (9034) using the scan interface mode and deploying the RT application onto the cRIO. Now I have the problem that even the simplest code (attached) fails to run smoothly. The output should just be activated in a constant frequency. But from time to time it sometimes is enabled/disabled way too long before getting back to it's rhythm. I think it could be some kind of wrong timing of the processor, but as I don't have experience in this topic I have to ask.
Does anyone know the exact problem or has tricks and examples on how to solve this problem?
Thank you in advance!
(3,114 Views)
Hi haagy,
As long as there is a Rube-Goldberg in your code you shouldn't call it "simplest"… 😄
There is some network communication in your loop: this is non-deterministic and could hurt your RT determinism…
(3,046 Views)
Hi Gerd
Thanks for your answer. Could you tell me the best solution how to communicate deterministically between touchpanel-computer and the cRIO? Or how would you solve that problem?
Thanks!
(3,042 Views)
Accepted by topic author haagy
Hi haagy,
put the shared variable into a parallel running loop. This way it can be read at its own interval.
Use a local variable (or notifier) to send this En-/Disable signal to your "deterministic" loop. You might try to use a TimedWhileLoop for communication with the ScanEngine.
How did you configure the ScanEngine?
(3,039 Views)
This worked, thank you very much!
(3,030 Views)
