Timing errors-non diagram component
I am compiling code for NI5840.
In the code ,I am having multiple SCTL's of different clocks.(100MHz,40MHz,60MHz) and with streaming code of NI.
Without streaming code, compilations are successful.
With streaming code, I am getting timing errors 100MHz also. It is showing "non diagram element".
I have  put 5 compilations for the same VI.
All 5 got timing errors. But those timing errors are different from each other.
what is meaning of non-diagram element?
My code is taking  almost 90% of total slices. Does it affect the timing?
Thanks in advance.
(1,496 Views)
Hello ramya850,
Could you please refer to these articles, maybe they will help you:
Also, can you share the part of the code where you did those changes?
Best Regards,
Edgar Umrikyan.
(1,415 Views)
