Timing a case structure
Why would you need local variables for this?
Message 11 of 22
(2,478 Views)
Can you give me an overlay of the state machine?
Message 12 of 22
(2,439 Views)
I have designed a state machine VI for my application as you suggested. However i am facing a problem.  I have three states mentioned :
1. Waiting for sensors
2. Sensor 1 triggered
3. Sensor 2 triggered
The IR sensors that I'm using stays ON for 2 secs, and when sensor 1 is triggered, i disabled the sensor 2 and incremented the counter and when sensor 2 is triggered, I disabled sensor 1 and decremented the counter.
The problem is that for state 1, how do I wait for both sensors 1 and 2? I tried giving it sequentially using 2 case select functions but that does not work.
I have attached my VI
Message 13 of 22
(2,426 Views)
Could you also look at my VI above and suggest a solution ?
Message 14 of 22
(2,425 Views)
Here's a simple solution. This implies that the state of the first "TRUE" statement will be outputed.  You should also put a time delay in the "Waiting for.." case otherwise your CPU will be a 100%.
Message 15 of 22
(2,414 Views)
This works when pir 1 is cut followed by pir 2 wherein pir 2 gets disabled, but does not work vice versa (probably due to the linear  nature of search 1d array)
Message 16 of 22
(2,404 Views)
Ok, I took a look in the code and what you need is a queue state machine which allows you to add more then one state.
Message 17 of 22
(2,397 Views)
Could you throw in some more light on that?
Message 18 of 22
(2,391 Views)
Here's an example (very simple) of the most basic kind of a queue state machine.  I suggest that you get familiarized with the queues instead of using the example below (which is using array for the queue).  I disconnected the typedef.
Message 19 of 22
(2,385 Views)
I shall look up on queues, but the above vi doesnt seem to work
Message 20 of 22
(2,374 Views)
