Timing R-series AI
I am wondering about what are the options for timing an R-series AI that are spec to run up to 750 ks/sec?
As I understand, if I put an AI node in the fast enough loop on the FPGA target, the loop will run at  750 kHz?
Can I achieve any intermediate, but precise timings? What is the correct way of doing so? Same question for when I want to use external AI clock source, with external trigger as well.
One odd thing I find that none of the available base FPGA clocks are multiplicative of 750kHz? I also can't seems to figure out how I could use, for example, external clock that is running at 750kHz without jitter or skips, even in theory....
Message 1 of 1
(2,610 Views)
