Timer problem
Hi there,
I have a strange thing with some timers.
I have a main timer: This one is running during a specific time: Set time. When he reaches the Set time is stops. This is ok
This timer activates 2 other timers: 1 - Run timer
                                                2 - Stop timer
The first timer which has to start is: Run timer
After the run time is expired the Stop timer should be running
and on and on
After The main time is expired all the sequences are stopped. This is ok
See sample code
William Strijks
Running with Labview 6.1
Fieldpoint hardware
(2,814 Views)
Hi William,
If you change the case value in the main -loop according picture the counter runs. Does this help ?
(2,781 Views)
