you can wire the timeout terminal of the event structure. By default, the event structure will never time out.
Just wire 30000 msec to the terminal add a event case for the yes and
no button and send True to the End terminal of the while loop out of
the two cases.
Have a look at the vi, it should do what you wanted.
