Timed structure controls too small
I have a small problem with my fresh LabVIEW 2010 SP1 install. The problem should be visible from my attached image - the controls are simply too small.
Is there any way to enlarge the controls so I'm able to view the contained text?
Best regards
Miles
(2,395 Views)
Or is a font too big?
Take a look at your resolution, and the size of your fonts in the Windows appearance properties of windows.  Check your LabVIEW .ini file.  See if there is anything odd defined there in terms of LabVIEW fonts or block diagram fonts.
(2,370 Views)
