Timed loop senqronization
I have two timed loop. One is run without stop, other is start if an condition happen and end with another condition.
I want them to run senqronize. How can I achieve this. The senqronize blok in Labview provide senqronize start. This is not what i want, since
I can not start two loop at the same time.
(2,768 Views)
Hi eesen,
I have found this example program that shows you how to add a timed loop to a synchronized group of loops.  Please take a look at this, and let me know if this is what you were looking for or not.  My thought is that you can have a case structure that allows you to add to the synchronized group if your start condition is met.
Best of luck on your application, and have a great day!!
Ching P.
DAQ and Academic Hardware R&D
(2,752 Views)
Thank you
I will try it:)
Message Edited by eesen on 03-08-2007 06:12 AM
(2,730 Views)
