Timed State machine
Hi all,
In this VI I have to insert the total time of my test, the time of a waiting time once the test is started and the time of the recording.
So if "total test time" = 35s, "Time to record" = 5s and "Time to wait" = 10s I want to see 2 whole cycles unless I press the reset button or stop button before 30s.
I cannot understand how I can STOP immediately in every state of the state machine.
Can anyone help me? Thanks
(1,957 Views)
Hi Luka,
Comments:
  • There should be no While loops inside the states. You already have a loop around the whole statemachine, that's all you need…
  • The STOP button can be read in/before each case, there's no need for the event case in the IDLE state…
  • Using the event structure is tricky, especially when you lock the frontpanel until events are handled…
(1,910 Views)
  • Don't put a While loop around your timers.
    • Use "Time Has Elapsed" to go to the next state or stay in the timer state
  • You really only need one timer or "wait" state
    • Pass the time to wait to the timer state from the previous state
  • Don't put an Event Structure inside a state.
    • Use polling or events to read controls not both
=== Engineer Ambiguously ===
(1,874 Views)
Maybe this can give you some ideas....
(1,846 Views)
