Timed Loop not Executing
My timed loop fails to execute, despite the absence of errors in the code. I need a third eye to help figure out what I might be doing wrong here. thanks.
(2,461 Views)
Looks like it's wrapped in a stacked sequence, so it's hard to say. Maybe it is not getting to this frame of the sequence? Can you attach the full VI?
(2,420 Views)
Thanks Gregory. The sequence runs until it gets to the Timed Loop, where it seems to freeze without executing nor throwing errors
(2,413 Views)
I am not familiar with timed loops, and I'm not sure what advantage it gives you here. But, I would guess it is because your timer source is not sending any triggers. If I disconnect the timer source and just let it go to the standard 1kHz clock, it seems like the loop is running.
(2,408 Views)
thanks Gregory, it works. However, when I include the Fire Software Trigger Timing Source, I get an Error -805. Any thoughts on fixing this?
(2,401 Views)
Hi ooyeniyi,
did you read the error explanation?
Does your hardware even support such timing triggers?
Why do you want to create, init, execute and kill DAQmx tasks in a tightly timed loop?
(2,382 Views)
