Timebase data for high sample rate
Well, you can try to pm me but that interface is the same as the forum.
Message 11 of 13
(414 Views)
It wont let me attach anything to a private message either! This is weird, I've done it before. Would you be able to explain to me or maybe attach an example of how you would get a high speed clock? Rhys
Message 12 of 13
(410 Views)
Help>Find Examples. You can even set it to limit the examples to your hardware.
Basically, when you use the DAQmx Timing function, you can just set the source to Onboard Clock. The sample mode has to be either continuous or finite and your DAQmx Read should be NSamp and samples greater than 1.
Message 13 of 13
(405 Views)
