Time stamp problem
Hi!
I have a waveform chart, and  I use an "Elapsed Time" block that is converted to time stamp to control the time of the chart.
After the .vi had been running for 01:28:43, the timer suddenly changed to 13178:28:44. The hours are somehow changed to 13178. Is this a known bug, or might it be a programming error of some sort?
It was running as an .exe file, so I could not probe for errors.
Thanks for the help
___________________________________
Is my avatar the dog from the fraggle rock?
(2,406 Views)
I don't think the "elapsed time" is in fault here, I've used it in many application and never had problems with it... How do did you set the X scale format string?
Can you show bits of your code so it's easier to find out what your problem is?
Trying to help
Epictetus
Antoine Chalons
(2,395 Views)
