キャンセル
次の結果を表示
次の代わりに検索
もしかして:
Time out function in VISA configure serial port vi
I have some doubts regarding the time out functionality of "VISA configure serial port vi":
1) I have set the time out value as 10s while initializing the port using this vi. Does this mean that for any Rx operation happening on the serial port, it will wait for 10s for the data to be received?
2) Is this waiting functionality also valid on "bytes at port" vi which I am using before reading the port data?
Because in my application, the control at serial port is actually not waiting for 10s and is coming out before the desired time out (10s). Do I need to set this time out anywhere else apart from initialization at "VISA configure serial port vi"??
Can anyone please tell the steps to set this timeout for the serial port?
Thanks in advance!
0 件の賞賛
メッセージ1/3
3,624件の閲覧回数
Hi mnx,
1) No.
VISARead will return when a) the requested number of bytes is received, b) a TermChar is received (if enabled), or c) the timeout occurs before the requested number of bytes could be read.
2) No.
You only need to set timeout at SerialPortInit…
0 件の賞賛
メッセージ2/3
3,615件の閲覧回数
1. A read will return when the first of the following is satisfied:
   a. The number of bytes at byte count has been received.
   b. The termination character (if enabled) has been received.
   c. An error is detected.
   d. The timeout time has elapsed.
I am not sure what happens if handshaking is enabled and the other device pauses communication.
2. No. Bytes at port returns immediately. This is a status check and it would not make sense for a timeout to apply.
Without seeing your code and the data the remote device is sending, we can only guess. My first guess would be that you have termination characters enabled (default) and a termination character appears in your data.
Lynn
0 件の賞賛
メッセージ3/3
3,607件の閲覧回数
