Time measurement
Hi. I'm a LabView-rookie! I'd like to measure the time between two signal
peaks given to the serial port by an optical sensor.
Is it possible to poll only a specific pin (eg. CTS) and how can I realise
it with LabView?
(2,929 Views)
You can poll the CTS line using VISA. Open VISA session to com port, pass
this session to property node. For property, select Modem Line Settings/CTS
State. You can also look at the other handshake lines. As for timing, it
will not be very precise as you are relying on windows timing I presume.
If you want good timing precision you should use a DAQ board with a counter,
this will be much more precise than windows.
"Yves" wrote:
>>Hi. I'm a LabView-rookie! I'd like to measure the time between two signal>peaks
given to the serial port by an optical sensor.>Is it possible to poll only
a specific pin (eg. CTS) and how can I realise>it with LabView?
(2,929 Views)
