Time dilation of a curve with 1D array interpolation?
Greetings,
  I'm trying to perform a time dilation of a curve I was working on previously with the function 1D array interpolate VI. Basically I have to perform the dilation on each segment so each segment contains 100 points, where currently there are 60.
  I currently am working with two files (both are broken) to compare because I am unsure how to use the 1D array interpolate VI, and what I should enter for the fractional index. I know the output from the array in the first for loop has to go into the 1D array interpolate somehow/
   I am stuck!
  Thanks!
   TheLT
(2,723 Views)
Accepted by topic author TheLT
I'm good I figured it out,
Here's how to do it for future reference.
Code attached.
TheLT
(2,686 Views)
the vis write in labview....
why not put it in 8.6
(2,675 Views)
