Time/date to file upon command
I'm an absolute beginner at Labview and am only in posession of Labview 6.1 (so I can't open any new VI's).
I'm attempting to write the simplest code ever, which is that upon pressing "ENTER", the Time/Date is stored onto a spreasheet.
Ultimately, the point of this is recording the exact time, whenever the pressure reaches a certain value by pressing enter.
What I would like to do is make the spreasheet into Array format such as:
Time Pressure (psi)
12:01:21 100
12:03:22 200
12:04:24 300
So far I've managed to write a loop that records the time... every second and save it to file, since I don't know how to make the "enter" command. And even at that, the file will only record ONE value.
Please help.
Aquaphire
---USING LABVIEW 6.1---
(2,559 Views)
This should help if it saved correctly.
Message Edited by jhoskins on 06-22-2005 07:40 PM
Joe.
"NOTHING IS EVER EASY"
(2,547 Views)
Please find attached VI for your reference 🙂
As for the [Enter] to save data,
1. Right-click on the Save Button
2. Select "Advanced"
3. Select "Key Navigation..."
4. Assign a Key to the control
Done 🙂
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,539 Views)
