Time Scale Graph questions
    Hi, I am VERY new to Labview.  I am using Labview 7.0  with a PCI 6220 card.  I have a VERY simple VI that plots input voltage [+/- 10V] with respect to time. Currently the graph plots continuosly each time a measurement is taken [Tmax - Tmin = ~1ms].  I want to graph to instead plot a continuous graph with a curve that starts at Tmin = 0, and ends at Tmax=1min, giving me a complete curve.
Your help would be very much appreciated!!!
(3,316 Views)
BTT
(3,307 Views)
(3,299 Views)
Hi heepofajeep,
    Here's a screenshot I hope will help you.  Basically, if you append the waveform each time through the loop, you can display it all on the graph at the same time.
Brian B
Account Manager
(3,262 Views)
Thank you, the picture is very helpful.  My only question is, how do I insert the constant 'block' that is outside the While loop with the pink outline?  Thanks!
(3,240 Views)
You can't with 7.0. It's a waveform constant but in 7.0, you can only have a waveform control on the front panel. Just go to the front panel and select it from the I/O palette.
The other way to graph continuously is to right click on your graph and replace the graph with a chart. You don't have to use the build array then. You do have to set the chart history length to be large enough though.
(3,231 Views)
