Time Delay while generating output signal using NI PXI 4461
Hi, I have problem in generating voltage
with the NI PXI-4461. I try to simulate a 3VDC signal using the NI PXI-4461 but
in the measurement result, I have a delay of 0.08 sec.
(2,735 Views)
This is the result i have from my output. Please help me on this. Thank you
(2,733 Views)
Wire error cluster from analog output to analog input.
If it doesn't help, wire above error cluster through sequence structure with time delay in side.
(2,718 Views)
