Time Delay between two triangular signals
I will be having one triangular generated waveform, and after some time, I should receive the same signal but with some time delay (using USRP). Is there a way to find that time delay?
I have a very basic VI where I simulated the received signal by another signal generator but with a phase shift.
I actually have another issue in the attached VI that the two signals do not appear together on the same chart although I suppose I did the right step by bundling them as I have read on the forum.
Thanks.
Message 1 of 12
(5,215 Views)
Hi Hefny,
you might use a correlation function:
I also see both signals in the chart… 😄
Message 2 of 12
(5,170 Views)
Unless your two signals arrive within 100ms, you won't see anything interesting, because you are only taking 100 samples at a time (and only keeping one point (1% of the signal!) for the chart). try to not use dynamic data. It's too opaque.
Do you have a more reasonable simulation? Are these "signals" short pulses? Best would probably be to acquire both channels simultaneously, continuously, and hardware timed and keep a sufficient history in a buffer. Analyze the buffer once both signals have been received.
What are typical timings between the two signals? (nanoseconds? Minutes?)
Message 3 of 12
(5,164 Views)
thanks for your reply.
I got your point why I am not seeing the two signals, but if not use dynamic data, what to use?
I actually want to transmit an FM modulating triangular pulse and receive it, then do some analysis.
I assume the delay will be in melli seconds.
Message 4 of 12
(5,161 Views)
Hi Hefny,
use waveforms or even plain arrays of samples…
The DDT wires hide too much information!
Message 5 of 12
(5,152 Views)
thanks a lot
If I have arrays (assume that the problem of displaying the signals is done), what do you suggest to get the phase difference between them (the methodology I mean)?
Message 6 of 12
(5,147 Views)
Sorry. I saw your reply very late.
It is very useful. Thanks a lot.
Let me ask you to guide me for a way to make analysis on these two signals (ex: phase difference between them).
Thanks again.
Message 7 of 12
(5,109 Views)
Hi Hefny,
I already suggested to use a correlation function.
Did you try it?
Message 8 of 12
(5,096 Views)
I tried it. But I get a straight line with negative slope. I doubt that this is the correct result, because even when I changed the two signals to sinusoidal waves, I still get a straight line as a result of cross correlation (although the result should be sine).
Message 9 of 12
(5,089 Views)
Hi Hefny,
the snippet I posted above doesn't result in "straight lines"…
When you have problems with YOUR VI you should attach it!
Message 10 of 12
(5,085 Views)
