Tick Count Giving Very High Result
I am fairly new to labview and am having a problem with the Tick Count (MS) function. In my program that is attached the count comes out very high after just a few seconds. For example after about 5000 ms the count reads 87,000,000 ms. This is a pretty simple program that I am just trying to have turn on lights at set times and turn them off at set times. I have put a numeric indicator in the first case so that I can see the tick count on the front panel.
Any help would be greatly appreciated,
Kelsey
Message 1 of 8
(5,090 Views)
The Tick Count is not a timer, it is a clock. It's giving you a tick cound in units of milliseconds between 0 and 2^32. You need to use it twice and subtract in order to time something.
Turning on and off lights at set times may be easier by using the Elapsed Time VI.
There is no loop in your VI, so I'm guessing you are using the Run Continuously button? You should look in to using a While loop along with Elapsed Time to do what you're trying to do.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 8
(5,086 Views)
Look at this little VI, and before you try to run it, decide (for yourself) what it is going to do.  Then give it a try.  Welcome to LabVIEW's Timing Functions.
Message 3 of 8
(5,073 Views)
I see an uninitialized shift register Smiley Wink
Cheers
Message 4 of 8
(5,071 Views)
So do I.  So what (in this particular case)?
BS
Message 5 of 8
(5,063 Views)
In this case, it means your LED will start at an inconsistent state as you know. It doesn't really matter for the flashing function, but for demonstration purposes I like to remove inconsistencies so we don't get a new topic in a week when a shift register like this is causing a bug in someone's code. Core 1 and Core 2 courses also emphasize initialized shift registers because the CLD marks off for it (unless it's an FGV of course).
In the end, I was just giving you flak.
Cheers
Message 6 of 8
(5,062 Views)
Of course -- flak accepted.  Find me at NI Week and I buy you a beer (or glass of wine).
BS
Message 7 of 8
(5,045 Views)
If I want to calculate timer I would suggest you to use get timer in milliseconds at different instances and find the difference of two which gives actual timer
Message 8 of 8
(5,041 Views)
