Tic Markers not showing up using marker spacing
Trying to get the Markers to show up at the logarithic intevals on the x-axis of the graph, particularly, 0.5, 1, 5, 10, 20, 30, 50, but I will take .10, 1.0, 10, 100.00.  I was looking at the Marker Spacing [] but wasn't able to understand how it works.
There was another message that indicated that the order of changing the custom settings may revert certain X,Y graph settings.  If that is the case, what is the recipe to setup an X,Y graph and display the markers?
-Regards,
Testing and Validation @ Neuronetrix
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(2,652 Views)
Hi eximo,
The following link can help explain some of the scaling properties for graphs: (http://zone.ni.com/reference/en-XX/help/371361J-01/lvpage/pp_scales_db/). You will want to right-click the graph, select properties, then select scales, then make sure 'log' is checked. I hope this helps!
Best Regards,
Roel F.
(2,596 Views)
