Threshold with tolerance
I have the envelope of a voltage signal. I would like to apply a threshold on this signal with a tolerance, like 10+/-2.
I just did a comparison with a equal or more, but I can't find how to put a tolerance. Do you have any idea?
Thanks a lot for your help!
Message 1 of 9
(7,000 Views)
If you are trying to see if the value is withing a range, then use In Range & Coerce.
Message 2 of 9
(6,992 Views)
It is not exactly what I want. My signal is joined to this post. I want to convert my signal in a binary, but I don't want the very small "jumps". It is to control a device, and it is going to shudder if the threshold detect these ones. Do you see what I mean?
Message 3 of 9
(6,985 Views)
Ah, so you want something with hysteresus, like a Schmitt Trigger digital chip.  Give this VI a try.  It should replace your comparison logic.
Message 4 of 9
(6,953 Views)
Well actually, what you sent works, but doesn't give me what I was expected.. I collect data that most of the time goes quickly under the threshold and goes back above. I would like that my program doesn't "see" when it goes quickly under the threshold. And I can't just increase the value of the threshold or I'm going to lose data..
Message 5 of 9
(6,945 Views)
Then I would add a moving average.
Message 6 of 9
(6,917 Views)
There are many ways to manipulate / filter / analyse data.   Mean filter, Median filter , all kind of stuff.... But the most wanted and simple 'Do what I think I need'-filter is hard to realize in a general way 😉
Please explain in more detail what you need to do.
You measure a signal, please provide a data sample, that helps us to provide ideas and test them. Just copy the graph with the data into a new vi,EDIT- MAKE CURENT VALUES DEFAULT, save and post that vi.
If YOU analyse the data, what steps are YOU doing (what rules do YOU apply) to get the result you need?
That information is needed to build an algorythm 🙂
For me it sound like you need median filter and a quantisation.... or maybe something with a hysteresis or a window like trigger ?
Greetings from Germany
Henrik
LV since v3.1
Message 7 of 9
(6,890 Views)
I can't send the vi, it is a program I can't share online.
But I can describe my program:
I am using Daqmx to receive data from a sensor (Daqmx read, analog input, waveform, N channels and N samples). Then, I collect the offset during 3 seconds. In my real-time acquisition I remove the offset, I do the absolute value, and I filter my data (butterworth low pass, 4th order, cutoff at 10 Hz to have the envelope). I apply a threshold and a RMS to delete the jumps I was speaking about earlier. It seems to work now. But I don't know if what I'm doing is the best way. I am using the Express blocks to filter, remove the offset (Formula) and do the RMS.
And most of my data are Dynamic Data.
I'm not used to Labview, so if you have advices or suggestions.. I know it is not easy without seeing the vi, I am sorry about that.
Thanks for your help!
Message 8 of 9
(6,863 Views)
Message 9 of 9
(6,861 Views)
