This method or property is not available because the clipboard is empty or not valid"
when usings the Word_insert_table.vi sometime's we got the message: "This method or property is not available because the clipboard is empty or not valid....."
What is the reasons for this and what can I do to prevent this error?
Thanks Huub
Message 1 of 12
(9,792 Views)
Is it a vi that you developt by yourself?
I canot find that vi in my library.
Can you post your code so we can help you more with that?
B.
Benoit Séguin
Software Designer
Message 2 of 12
(9,784 Views)
Hello Benoit,
The vi is part of the Labview report generation toolkit for Microsoft Office.
Thanks for help, Huub
Message 3 of 12
(9,777 Views)
Hi knipph,
do you use it in this way (see the picture please), or do you use the single "Word_insert_table.vi"?
Mike
Message Edited by MikeS81 on 05-30-2008 03:45 PM
Message 4 of 12
(9,771 Views)
OUPS,
            I dont have that installed in my LabView. I just dont use it. Mabe later.
Sorry.
B.
Benoit Séguin
Software Designer
Message 5 of 12
(9,767 Views)
Hi Mike,
yes, in principe is this the configuation, I use some vi's more because I insert also text and change fonts.
Message 6 of 12
(9,731 Views)
Hi knipph,
can you upload your vi? I could check it on my pc.
Mike
Message 7 of 12
(9,729 Views)
Hi Mike,
This is the vi , after this i Print the result as you already did show.
Thanks Huub
Message 8 of 12
(9,715 Views)
Hi Huub,
this example works for me without your error message. Where do the message come from, from LabView or from Word?
Mike
Message Edited by MikeS81 on 06-03-2008 07:09 AM
Message 9 of 12
(9,697 Views)
Hi Mike,
I think is has someting to do with Word or the combination. My interpreation is that Laview has not filled the passed buffer as Word needs is?!?
I have attacht the complete message.
Note that I have add the text "State Print WO[" and  "-WO--2146823683-TS--2146823683-VI-2146823683-MA--2146823683]" is add by my Errror handler for traceability reasons.
This error is not occuring allway's some time it work perfect and somtime's not.
It looks like is is in combination with a certain PC, on my own PC I can not reproduce it.
Thanks for your help, Huub
Message Edited by knipph on 06-03-2008 01:52 AM
Message 10 of 12
(9,692 Views)
