Thermocouple Reading Changes when using Different Computer
I have a test setup that includes some voltage AIs and a single thermocouple (type K) input coming in on the same SCB-68 block. Originally I had a computer running my LabVIEW code and using a PCI-6036E card to capture the data (LV7, DAQmx being used). I had to swap in a different computer that uses a PCI-6024E card instead. Now the thermocouple reading is always 6 degrees above actual temperature it should be reading. Is there any (semi-)logical explanation as to why this is happening?
Neil
(2,924 Views)
You gave up 4 bits of precision when you moved from the 16-bit 6036 to the 12-bit 6024. The problem is most likely compounded by an inappropriate gain setting on your thermocouple channel(s).
A DAQ expert Alliance Member like us could be very helpful to you! We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,924 Views)
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(2,924 Views)
Oops, sorry my mistake. I changed to an NI6034E not NI6024E... I mistyped it in the original question I'm sorry. As far as I can tell I have everything set up identically (channels, setup etc.) *except* the fact it's a 6034 card in a different computer.
Thanks for the response,
Neil
(2,924 Views)
