Thermal Control Simulation VI?
Hi
Does any one have a copy of the VI for the project below?
It is a Thermal Control Simulation exercise that was part of a Labview Hands-on seminar.
Any help would be much appreciated.
Kind Regards
Fergal
Thermal Control Simulation Block Diagram.jpgThermal Control Simulation Front Panel.jpgSeminar Title.jpg
(3,320 Views)
Hello Fergal,
Welcome to the Forum!
I haven't seen this VI / Hands-On seminar before. Where exactly is your question leading towards? If it is a more general question that you wanted to get an answer for by looking at the VI's code, I or someone else on this forum might be able to help without having the VI in front of us.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,275 Views)
Hi Ikaiser.
Thank you for the response and welcome.
It is really the full VI that I am looking for to use as part of a project.
I am fairly new to LabVIEW and this would be useful for the project.
I thought the seminar might be a popular course and that the solution might be out there.
(3,265 Views)
I understand. There are other sources for inspiration / starting off, maybe one of these is sufficient for you?
  • The example VIs and example projects shipped with LabVIEW: Goto menu "Help » Find Examples...". From the screenshot I'd guess that you are mostly interested in the examples found in "Tasks » Fundamentals" and "Tasks » Hardware Input and Output"
  • The Example Programs section here on the forums
  • The Code Sharing search engine on NI's website (this one knows the example programs on the forum as well as from many other sources)
CLADMSD
(3,249 Views)
