The while loop in LabVIEW can be randomly interrupted?
I want to know whether the while loop in LabVIEW can be randomly interrupted,how do it.
(2,915 Views)
Accepted by topic author 刘狗蛋
you cannot "interrupt" structures as is dictated by DATAFLOW…
(You can stop your while loop once all code inside has finished execution.)
You might use case structures to place code inside to be able to dis/enable its execution. Once you do this you should also think about state machines!
(2,911 Views)
