The way of changing color in blinking lights
Hi. Please tell me the way of changing color in blinking lights.
in the present program,
There is a slider and it's property node with blinking and Fillcolor.
Property node with Fillcolor conected color box with blue.
so, I run program then slider turn on and off and showing blue and yellow.
I want to change the yellow to another color!!
I am look forward to your response!
(2,691 Views)
Hi Kazu
There are two ways:
1. You can change the blink color in the LV-options (tools >> options >> color), which is a general setting.
2. You make a little vi that changes the color of the control using a property-node. This way is more flexible, as you can use every color.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,688 Views)
Hi, becktho
Your advice help me to solve this ploblem!
Thank you !
(2,680 Views)
