The value read by visa read VI is not correct!
Accepted by topic author song403
ok. so I should type command like"*OPC? :CALC1:MARK1:X?;Y?" before read value?
Message 11 of 13
(646 Views)
You still have not looked at the code in the driver?
And why did you mark this question as the solution?
Message 12 of 13
(642 Views)
In my program, I use ":CALC1:MARK1:Y?" to fetch the measurement value. I use read command to got the value. However, the device need some time to move the value from memroy to output area. So I read it too fast. After add "*OPC?" command before read command then the value is correct.
Message 13 of 13
(617 Views)
