The type of the source is 1D array of double [64-bit real (~15 digit precision)]. The type of the sink is double [64-bit real (~15 digit precision
I loading the same project on a different LabVIEW machine and seeing the error "The type of the source is 1D array of
The type of the sink is double [64-bit real (~15 digit precision)]."
This is not an issue on the other LabVIEW machine. Both are running LabVIEW 2017 SP1.
Message 1 of 9
(3,009 Views)
looks like the input is not expecting an array just a single float.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 9
(3,002 Views)
Instead of showing is your entire desktop with a disorganized truncated diagram with hidden wires, attach the actual VI to do us all a favor. Thanks.
What kid of report are you generating (HTML, Word, Excel)? (not visible in the image!). Do all machines have the same version of office installed? Same version of the report generation toolkit?
What is the exact name of the function rejecting/accepting the broken wire? Append table to report requires a scalar for the column width, so it might be more interesting to see the code where the wire is NOT broken.
Message 3 of 9
(3,001 Views)
It generates a HTML report. Same version of Office is installed on both machines and the same version of Report Generation Toolkit.
Message 4 of 9
(2,978 Views)
As mentioned, "append table to report" requires a scalar for the column width so we expect the code to be broken if you wire an array. If it is NOT broken on some computers, we need to find out why, but we don't have sufficient information. We cannot really tell with 100% certainty where the wire actually connects by looking at a messy code picture.
As a first step, attach your VI.
Message 5 of 9
(2,975 Views)
Attached are the VIs that are encountering the same issue.
Message 6 of 9
(2,972 Views)
Hi Jay,
there's a missing "tables" subVI in your attached VIs.
It should be located in vi.lib/Utility/NIReport.llb/Win, but it isn't on my LV2021 installation. Other RGT functions load fine for me…
In "print pl" you use AppendTableToReport instead of the missing "tables" subVI, and so it offers a different ConnPane!
Message 7 of 9
(2,961 Views)
@GerdW wrote:
Hi Jay,
Hi Gerd,
   I've attached the tables.vi file. Thanks!
Message 8 of 9
(2,921 Views)
This sounds like someone might have been editing inside vi.lib
If you edit the system subVIs, your LabVIEW installation becomes incompatible with other installations and this kind of error can occur. You can check by comparing against a third, fresh installation of LabVIEW (on a third system, if you are concerned with recovering the edits to the system library, as they may be lost otherwise) or by comparing the offending subVIs on both installations.
Message 9 of 9
(2,884 Views)
