The sample rate in my code is too low. Is there a way to make it run faster?
Dear Sir,
    I am a LabVIEW customer, and just have a question about LabVIEW.
    We are running a code of "Wirebonder Project", but find the sample rate is too low. I'm wondering if there is a way to make it run faster. (I have
attached the code here.)
    Thank you very much!
Yours Sincerely,
Xian Zhang
(2,423 Views)
Hi Xian,
What system are you running this code on and are you using the LabVIEW Real-Time Module? There is a presentation online on Optimizing and Benchmarking Real-Time code with useful related links as well as other articles in the DevZone on things like Benchmarking an Application Using LabVIW Real-Time and DAQmx.
As you can see, this is not a simple question, so take a look at the information in these links and see if you can narrow down what in your code is running slowly and how much you might be able to improve the speed.
Stephen S.
Applications Engineering
(2,379 Views)
