The output of the Read File VI is not a cluster?
I have write a cluster into a file, and when I read it from the file with Read File VI, its output can't be wired with Unbundle VI.Why?
Thank you!
(2,454 Views)
Hi
You have to tell the read file vi what kind of data it has to read. So wire a constant of your cluster to the corresponding input.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,451 Views)
