The network share variables don't work when I convert VI to Application Files
Hello.
I'm using a host PC and two sbRIOs to make a control system now.
And I have tested the system without any problems worked as VI files.
But when I convert the sbRIOs VI to Application files, the system doesn't work as before.
As far as surveyed, the network share variables( NSV ) running in sbRIO1 are not run as usual, however there's no problem with the NSV in sbRIO2 .
Can anyone tell me what's wrong with the variables in sbRIO1?
At first, I have used all of the NSV as custom defined, and now the NSVs in sbRIO1 are changed to booleans or arrays.
(2,305 Views)
Hi Damon6102,
I'm glad to hear that you changed the NSV from type definitions to a RT-supported data type.
If the NSVs still aren't working, however, I would suggested checking #5 under "Troubleshooting for a Real-Time (RT) System"
Is it possible that the new booleans/arrays you created exist as front panel objects? Such booleans/arrays will need to exist as shared variable nodes on the block diagram to properly update.
"Archived: Troubleshooting Network-Published Shared Variables"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6vdSAC&l=en-US
(2,253 Views)
