The eig() instruction in my matlab script is causing an insane object error
I have matlab script in a vi that I want to use to calculate eigenvectors and eigenvalues of a large array. I started with a small array (3x3)and it calculated them incorrectly. However when i ran the same script in Matlab the correct values are returned. On top of that when I try and save the vi after running it I get an insane object error at FPHP+DC. I tried rewriting the vi without copying and pasting etc. but it wont go away. I then simplified the vi to simple integer addition and removed the eig()instruction and error doesn't appear anymore, so it seems that the eig() instruction is causing all of this and it isn't even giving the correct answers! Where does this leave me? I can't get the e
igenvectors using the Labview vi because the array i will using eventually is (944x944) and the labview vi gives me an error saying I have exceeded maximum iterations. This is why I am using Matlab in the first place.
Thanking you in advance!!
Marion
Message 1 of 1
(2,542 Views)
