The doc for the Array Subset function shows function extensible
In LabView 2010 the doc for the Array Subset function shows that the function is extensible with multiple indexes and lengths. I can't seem to extend the function for multiple indexes. How do I do this?
Is the documentation for the function in error, or is there another Array Subset function somewhere that can do this?
(2,918 Views)
Accepted by topic author dbaechtel
Array Subset Details
When you wire an array to this function, the function resizes automatically to display index inputs for each dimension in the array. If you wire a 1D array to the function, the function displays the index inputs for an element. If you wire a 2D array to the function, the function displays the index inputs for a row and column, respectively. If you wire a 3D through nD array to the function, the function displays the index inputs for a page.
(2,913 Views)
Thanks.
I missed that explanation.
(2,907 Views)
