The control "reference" matching the pattern
Can someone offer some insight to what the following message means. It is generated by the VI analyzer.
"The control "reference" matching the pattern "^[Rr]ef" was not located in the user-specified terminal position (UL)"
Thank You
Jim
(2,331 Views)
You have a control on your front panel named "reference" which is connected to the connector pane on the wrong side.
The "^[Rr]ef" means that LabVIEW looked for any control starting with "ref", or "Ref". The (UL) means Upper Left. Just look at the Analyzer setup under "Terminal Connections" or something like that.
Richard
(2,324 Views)
