The cluster conundrum solved in 2010!
I'm sure Darren will get this into a nugget soon (if he hasn't already) but one of the features of 2010 is the ability view a cluster constant as a icon on the block diagram - great but this is fairly well known...
Well, I just had one of those fun accidental discoveries (maybe I just didn't read all the "New in 2010" literature well enough) but when I was poking around on my block diagram I found that you can quickly go from "cluster constant as icon" to the messy data/type view with a simple double click on the boarder.
Double-click to toggle cluster constant "icon" view - brilliant!
- Jolt
(2,544 Views)
Th eonly problem with that is it goes back to the orginal size before you made it an icon. I have some big clust constants and this defeats the propse of using this feature because everything grows if you have that selected in the tool options. I made this suggestion in the idea exchange.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Need-Edit-Window-for-New-Cluster-Constants/idi-p/12082...
Tim
GHSP
(2,477 Views)
