The best way to simulate LabVIEW to SCPI parser (host)
I have a project that simulate the LabVIEW to command parser (example SCPI) via TCP/IP.
Including two ways communication between host (LabVIEW) and client (LabVIEW, C++, C#,...) .
It's look like an instrument that support SCPI.
What is the best LabVIEW achitecture or tool for delvelop above requirements?
Thank you.
PS. Sorry for my little English.
(5,371 Views)
Just to clarify,
Are you looking to develop a LabVIEW code which will simulate SCPI command instrument hardware?
(5,326 Views)
I would use 3 different loops: TCP/IP Read, TCP/IP Write, and general processing.  Use queues to send data between the loops.
GCentral
(5,296 Views)
Just to clarify,
I'm not the OP but I found this post because I have a similar project in mind where I want a piece of LabVIEW code to simulate a SCPI device.  This includes paring incomming SCPI commands and performing actions upon it and sending back proper responses (to be defined by me.)
What is available out there for this, if anything?
(5,027 Views)
There are several TCP example VI’s that ship with LabVIEW if you are interested in taking a look at those. You might be able to simulate your desired functionality that way. If you navigate to Help, Find Examples, and double-click on the Networking folder you will see the TCP and UDP example VI’s.
Ross S.
Applications Engineering
(4,993 Views)
I was hoping there was an open source implementation of a SCPI Command Parser writtin in LabVIEW much like this 'C' implementation https://github.com/j123b567/scpi-parser
(4,985 Views)
No, I've never seen a LabVIEW implementation. You could build a dll from the code and call that in LabVIEW.
I'm curious why you need to simulate an instrument. The IVI drivers have built-in simulation. Would that work for you?
(4,967 Views)
