The Ordinal 2011 could not be located in the dynamic link library nidaq32.dll
After installed BridgeVIEW 2.1, labview 6.1 DataAcquisition function showing the Ordinal 2011 could not be located in the dynamic link library nidaq32.dll
(3,018 Views)
> library nidaq32.dll
You should have choosen the Custom Installation of BridgeVIEW and
deselct any hardware drivers. The NI-DAQ drivers which come with
BridgeVIEW are A LOT older than the ones which come with LabVIEW 6.1.
Of course the installer should care but the problem is also that the
installer technology used for those two versions is entirely different
so the old installer is most probably not aware that there is a newer
version already installed.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,018 Views)
