The DB tools doesn't work with Microsoft SQL
I am tring to write series of waveforms to a database. The DB tools doesn't work with Microsoft SQL, but when i replace the SQL with Access, it works fine. I have to use SQL in the application.
Any advice pls?
longing for your reply.
(2,725 Views)
I don't use it myself, but what I can tell you is that on the installation CD are a number of readme's and a special folder about SQL compatibility. There is even some fix executable on it. I suggest you check that out.
(2,716 Views)
Right off hand I would say the problem is that you are connecting through ODBC. Try the native SQL Server driver, your connect string should define the provider as "SQLOLEDB.1".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,709 Views)
yes mikeporter, you are really right, it does work fine after i put a .udl file created using the driver "Microsoft OLE DB Provider for SQL Server". Thanks very much!
(2,688 Views)
