The Clear View: Remote control via web
Dear LabVIEwer,
I do not clearly see the remote control of vi via web.
Can anyone explain me the way to control vi via the web, please...???
Server: Test.vi
Labview 6.1(FDS)
Internet Toolkit
Client: Only Internet Explorer/netscape with TCP/IP
NOT installed LabVIEW environment******
Problem : I apply HTTP server, publishing web documnet(embedded) to control Test.vi. I do not see the front pannel of Test.vi even I can only see the text upper and lowwer part of the boundry of vi.
Target: I do not want to install LabVIEW at client machine. I do not need snap shot / monitor. And I do not want to use LaVIEW Player. So please guide me the way to control Test.vi via the web around the world
Welcome any suggestion, example and documnet.
Thanks for your kindly shared information in advnace.
Best,
Jo
(3,697 Views)
In order for the client machine to see the application via the web, the client machine has to have the Labview runtime engine installed. The Labview runtime engine can be found at:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1065?opendocument&node=132060_US
(3,697 Views)
You don't specifically mention doing it, and it isn't necessary if you
format the HTML correctly, but I'd recommend opening the Tools>>Web
Publishing
Tool... dialog. It will help you to generate the HTML snippet that will
show the live remote panel.
As for what will have to be installed, the first time the panel is
viewed, the helper app, which includes the LV runtime will need to be
installed -- very much like a pdf viewer. There is no need for the
player or the editor to be on the remote machine though.
Greg McKaskle
(3,697 Views)
Dear 6string,
Thanks for your kindly information.
But I do not want to install LabVIEW run-time engine on the client. My client has only Internet Explorer/Netscape with TCP/IP networking.....
Anyhow, thanks for your time...
Best,
jo
(3,697 Views)
Jo,
You have a couple of options. The easiest and best way to control a vi via the web is to use the remote panels feature in LabVIEW 6.1 The other is to use the Internet Toolkit with CGI scripting. The first will require that the run-time engine is installed on the client machine, not LabVIEW the application but just the engine. I'll provide some information on both options.
Remote Front Panels
This provides a very quick to deploy method. It's a matter of just saying publish and the VI can be controlled. The method is also very efficient for control so you will see good performance. If you're worried about people not knowing they need the run-time engine you can put in detection code into your html that prompts the user for the run-time engine if the client doesn't already have it installed.
This method provides the best control in my opinion of a VI remotely. Using CGI with the Internet Toolkit will not provide as smooth control as using remote panels, or deal with multiple simultaneous users without a lot of coding on your part (for multiple users there is a license needed).
You can see some remote panel implemented pages here:
http://www.ni.com/academic/live_experiments.htm
Here are some useful documents on remote panels:
Remote Front Panels Presentation
http://zone.ni.com/devzone/learningcenter.nsf/03f7c60f17aad210862567a90054a26c/2ad405a06ebed71586256c4e00621c73?OpenDocument
Developing Remote Front Panel Applications - Info on desiging your applicaiton as well:
http://zone.ni.com/devzone/conceptd.nsf/webmain/E789515B9976253786256B1F007E039B?opendocument
Distance Learning using Remote Panels
http://zone.ni.com/devzone/conceptd.nsf/webmain/7BD0B01FCF3CF61A86256B510059F0FB?opendocument
If you look at the source of any of the distance learning pages on ni.com you'll find the detection html for the run-time engine:
I got the above from:
http://www.ni.com/webappdemos/tempcontroldemo.htm
As for using the Internt Toolkit only and not remote panels (if you can't have the run-time engine installed). This requires quite a bit of knowledge of html and cgi scripting. I've found some examples on ni.com:
If you want to control via a button that is not part of the VI and have an action taken:
http://zone.ni.com/devzone/conceptd.nsf/webmain/0A81885925C72F5386256802007B9611?OpenDocument
If you actually want to be able to interact with the VI controls then the only things I've been able to find requires an image map. The only example there doesn't have a great rating but it's something:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/42cf377dd207ecc786256530006876c0?OpenDocument
Haven't ever done the image mapping myself. If you can at all deal with installing the run-time engine on the client machines life will be much simpler, but if you can't I'd be interested in hearing how your use of the CGI VIs goes.
Kamran
An
(3,594 Views)
As I posted earlier, the LV plugin is very similar to the PDF viewer
from Adobe. Something must be installed. If you cannot have the
runtime engine installed, then you do not want to use the plugin and you
should look at something like remote desktop, Timbuktu, PC Anywhere, or
similar remoting that is low level graphics based.
Greg McKaskle
(3,594 Views)
Dear Kamran,
THANKS A LOT FOR YOUR KINDLY INFORMATION.
This is what I 'ld like to know.
This is really complete solution for me.....
Thanks a lot for a clear view.....
Best,
Jo
Assumption University
Bangkok
Thailand.
(3,594 Views)
