Testing without physical channel
I am developing a Labview VI to control a DC motor.
I am using DAQmx and I will use the timing block and the create channel one.
I would like to know if I could test the VI without having the physical channel like with a pulse generator (square waveform).
Thank you very much,
Alexander
(2,677 Views)
could you able to elobrate more, i think its not to tough to control DC motor, Please tell me the setup you are using.
(2,668 Views)
An encoder will generate voltage pulses and is linked to the acquisition card.
I am developing the program but I don't have the encoder with me.
If I link the square waveform to the "Create channel" block from DAQmx, it won't link.
It will link if I wire the physical channel, witch is not with me.
Thank you,
Alexander
(2,660 Views)
