Testing a function generator using PXI-5412
I want to test a function generator example by reading it from a PXI-5412, but I dont know what do I suppose to read the input from.
(3,175 Views)
I don't understand. The PXI-5412 is a function/arbitrary waveform generator and it cannot read anything. It is an output only device. To check the output, you can connect it to a scope.
(3,169 Views)
Thank you Dennis,
I was confused myself, I did not know what to check with the PXI-5412. But, now I know is to output something.
(3,155 Views)
