TestStand can't find VI's after I build an application with applicationbuilder(LV 8.5)
I have made a vi where there is a call to TestStand. In this Sequence file there are several call's to vi's. Now I wanted to make an application from the vi that calls teststand, so I did. After I made the application with applicationbuilder(Labview 8.5) he gives the error that TestStand can't find the vi's(see attachement) what am I doing wrong can somebody tell me?
Thanx
(2,438 Views)
Hello W1ldb1ll,
there is a knowledge base about a possible cause of this issue; http://digital.ni.com/public.nsf/allkb/BF8FDB593881BB678625738B0083B508?OpenDocument
Please verify the labels, hopefully this will solve your problem. Please let me know if it doesn't.
Martijn
Martijn S
NI Netherlands
(2,437 Views)
Thanx for your reply but the problem is only after I make an application of the VI, When I run the VI under LabView(8.5) There is no problem. To be sure about your suggestion I checked the labels but there are no additional spaces. Still thank you very much for your solution and maybe you have another suggestion.
Dennis
(2,431 Views)
