TestStand/Python best for adding SSH to LabVIEW?
Is Python in TestStand the best way to incorporate SSH into LabVIEW development?  I'm asking this because I have never used TestStand, but we often need to use SSH for our testing.  Is it worth learning TestStand for this sole purpose?  Example: Python SSH to run a command, end python script and continue with LabVIEW test sequence
Studying for CLA.
LabVIEW, inherit from social media habits!
(1,716 Views)
PuTTY has an SSH CLI that you can use with LabVIEW system exec, if that helps.
Bill
CLD
(Mid-Level minion.)
(1,704 Views)
1. There is a Python node in LabVIEW.  So no need to pull in TestStand for this.
2. What I did was use an open source .NET library, which you can find here: https://github.com/sshnet/SSH.NET .  I then created a LabVIEW class around that which has been used successfully on several projects.
(1,690 Views)
