Test the reading of wireless frequency transmitter directly on PC using labview
Hello, We are using Wireless Frequency transmitter which is sending the data directly to PC using wireless communication and test the frequency readings of industrial machines and looking for better guidance to use LabVIEW which will be easy to monitor the readings of the sensor by using the software in laptop only.
Your leads on this will be appreciated
Note: Sensor is using Mesh module to transmit and receive the data using software digimesh recommended by the company but needs to use the received data in LabView
Message 1 of 1
(2,184 Views)
