Test Stand 3.1, Labview 7.1 MechFactoryCWrap.cpp(649) error
Hi all, I am having some issues with an error and I can't track it down to the problem as of yet. What is happening is after a couple of cycle of opening TestStand and closing it with a few VIs loading in the background all of the 3D controls vanish and TestStand locks up. The warning message I get is something to do with MechFactoryCWrap and sometimes render.cpp with the error pointing to OpenGL.
Below is a snippet from the failure log.
D:\lvmerc\src\source\execsupp\MechFactoryCWrap.cpp(649) : DWarn: Max space cannot be zero; changing to -1 (unbounded)
$Id: //labview/branches/Mercury/dev/source/execsupp/MechFactoryCWrap.cpp#3 $
0x00A35B37 - LabVIEW <unknown> + 0
0x00A346F5 - LabVIEW <unknown> + 0
0x00A3688C - LabVIEW <unknown> + 0
0x00A349A3 - LabVIEW <unknown> + 0
0x00A3565C - LabVIEW <unknown> + 0
0x06993BD3 - <unknown> <unknown> + 0
0x06911A50 - <unknown> <unknown> + 0
0x00A09110 - LabVIEW <unknown> + 0
0x8B535CEC - <unknown> <unknown> + 0
Any help would be appreciated.
Dean
(2,780 Views)
Hi Dean,
Have you attempted to open the VIs of interest in LabVIEW 7.1? Does it report the same error?
Attempt to open and close LabVIEW multiple times using the same VIs.
Nestor
(2,761 Views)
It only happens within TestStand 3.1. I can make it work by opening one of the VIs and run it before opening TestStand. But since this will be used in a manufacturing enviroment that is not a work around.
(2,752 Views)
Hi Dean,
This failure is linked to LabVIEW 7.1.
This was reported to R&D (4APEN0XP) and was fixed in LabVIEW 8.2.
If you would like to evaluate LabVIEW 8.5, please follow the link below:
Nestor
(2,737 Views)
